EpmBasicVariablesView
Returns a table containing a list of all Basic Variable-type variables in an EPM Server.
Syntax
SELECT * FROM EpmBasicVariablesView()
Resulting Fields
•Name: Name of the variable
•Description: Description of the variable
•EU: Engineering unit configured in the variable
Usage Example
To return data from all Basic Variable-type variables containing the expression "Elipse" in the Name field, use the next declaration.
SELECT * FROM EpmBasicVariablesView() WHERE Name LIKE '%Elipse%'
