EpmQueryDatasetTimeInterval
Returns data from a query containing the configuration of pens and types of aggregation of the Dataset Server informed in the @datasetName parameter and with a Time Interval-type of period informed in the @startTime and @endTime parameters.
Syntax
SELECT Name, Timestamp, Quality, <type_function>(Value)
  FROM EpmQueryDatasetTimeInterval(<[string]@datasetName>,
  <[datetime]@startTime>, <[datetime]@endTime>)
Parameters
•<type_function>: Conversion function to define a data type for the resulting values on the Value column. Possible values are described on topic EpmReadPropertyFunction
•<[string]@datasetName>: Full name of a Dataset Server to search for, which must be between single quotes
•<[datetime]@startTime>: Initial date of the period to retrieve. This must be a String in the format yyyy-MM-dd HH:mm:ss
•<[datetime]@endTime>: Final date of the period to retrieve. This must be a String in the format yyyy-MM-dd HH:mm:ss
Result Fields
•Name: Name of a variable or variables retrieved
•Timestamp: Timestamp of data retrieved
•Quality: Quality of data retrieved
•Value: Value of data retrieved
Example
To return a table with the configurations of pens and types of aggregation of the ODBC_Dataset Dataset in the period between 10:23 and 10:25 of 12/17/2020, use the next statement. The type of RandomTags_Random1 pen is Raw and the type of RandomTags_Random10 pen is Interpolative with a 30-second interval.
SELECT Name, Timestamp, Quality, doubleval(Value) FROM
  EpmQueryDatasetTimeInterval('ODBC_Dataset', '2020-12-17 10:23:00', '2020-12-17 10:25:00')
EpmQueryDatasetTimeInterval function
