SIGN
SIGN
Returns -1 (minus one) if the value indicated in the @value parameter is negative, 0 (zero) if the value indicated in the @value parameter is 0 (zero), and 1 (one) if the value indicated in the @value parameter is positive.
Syntax
SIGN(@value)
Parameter
•@value: Numeric value to evaluate
