REPLACE
REPLACE
Returns the String indicated in the @text parameter with all occurrences of the @pattern parameter replaced by the @replacement parameter.
Syntax
REPLACE(@text, @pattern, @replacement)
Parameters
•@text: String from which the replacements must be performed
•@pattern: Pattern to replace in @text
•@replacement: Value that replaces @pattern
