LEFT
LEFT
Returns the left side of the String indicated in the @text parameter with the maximum number of characters specified in the @length parameter. If the @length parameter is greater or equal to the length of the String indicated in the @text parameter, the returned value is equal to @text.
Syntax
LEFT(@text, @length)
Parameters
•@text: Text to truncate
•@length: Maximum length of the value to return
