EpmQueryDataset
EpmQueryDataset
Returns data from a query with pen configuration, aggregation types, and period from the Dataset Server informed in the @datasetName parameter.
Syntax
SELECT Name, Timestamp, Quality, Value FROM EpmQueryDataset(@datasetName)
Parameter
•@datasetName: Full name of the Dataset Server to query, which must be between single quotes
Resulting Fields
•Name: Name of the variable or variables to query
•Timestamp: Timestamp of data found
•Quality: Quality of data found
•Value: Value of data found
Usage Example
To return a table based on the configurations from Dataset ODBC_Dataset, use the next declaration. The RandomTags_Random1 pen is a Raw-type and the RandomTags_Random10 pen is an Interpolative-type with a time interval set to 30 seconds.
SELECT Name, Timestamp, Quality, Value FROM EpmQueryDataset('ODBC_Dataset')
