EpmQueryAggregateFunction
Returns data from one or more variables, comma-separated, informed in the @node parameter, according to the format defined by the aggregation function indicated by the @aggregateFunction parameter.
Syntax
SELECT Name, Timestamp, Quality, Value FROM EpmQueryAggregateFunction(@timeZoneOffset, @startTime, @endTime, @sampleInterval, @aggregateFunction, @node)
Parameters
•@timeZoneOffset: Timezone to consider. Possible values range between -12 and 14
•@startTime: Initial date of the period to query. Users must use a String in the format yyyy-MM-dd HH:mm:ss
•@endTime: Final date of the period to query. Users must use a String in the format yyyy-MM-dd HH:mm:ss
•@sampleInterval: Time interval used to calculate aggregation, in milliseconds
•@aggregateFunction: Name of the aggregation function to use. Possible values for this parameter are described on the next table
•@node: Variable or variables to query. Users must inform the full name or names between single quotes and comma-separated
Possible values for the @aggregateFunction parameter
Value
Description
AnnotationCount
Informs how many annotations a variable has inside the sampling interval
Average
Calculates the average of data values with good quality inside the sampling interval defined in the @sampleInterval parameter
Count
Returns the number of data present in the sampling interval defined in the @sampleInterval parameter
Delta
Returns the difference between the first and last values with good quality inside each sampling interval
DeltaBounds
Returns the difference between the first and last values with good quality inside each sampling interval. It considers the Simple Bounding Values
DurationBad
Returns the time, in milliseconds, in which data had bad quality inside the sampling interval. Quality is defined based on the quality of data from interval's edges
DurationGood
Returns the time, in milliseconds, in which data had good quality inside the sampling interval. Quality is defined based on the quality of data from interval's edges
DurationInStateNonZero
Returns the total time, in milliseconds, in which a value remained different from 0 (zero) inside the sampling interval
DurationInStateZero
Returns the total time, in milliseconds, in which a value remained in 0 (zero) inside the sampling interval
End
Equivalent to the Interpolative function, but uses the original timestamp from the last value of the sampling interval
EndBounds
Equivalent to the Interpolative function, but uses the original timestamp from the last value of the sampling interval. It considers the Simple Bounding Values
Interpolative
Interpolates data from the queried interval, returning points according to the interval defined in the @sampleInterval parameter
Maximum
Informs the greatest value found on data inside the sampling interval defined in the @sampleInterval parameter. The timestamp corresponds to the starting time of each sampling interval
Maximum2
Informs the greatest value found on data inside the sampling interval defined in the @sampleInterval parameter. The timestamp corresponds to the starting time of each sampling interval. It considers the Simple Bounding Values
MaximumActualTime
Informs the greatest value found on data inside the sampling interval defined in the @sampleInterval parameter, except that the timestamp corresponds to the moment the greatest value found occurred
MaximumActualTime2
Informs the greatest value found on data inside the sampling interval defined in the @sampleInterval parameter, except that the timestamp corresponds to the moment the greatest value found occurred. It considers the Simple Bounding Values
Minimum
Informs the smallest value found on data inside the sampling interval defined in the @sampleInterval parameter. The timestamp corresponds to the starting time of each sampling interval
Minimum2
Informs the smallest value found on data inside the sampling interval defined in the @sampleInterval parameter. The timestamp corresponds to the starting time of each sampling interval. It considers the Simple Bounding Values
MinimumActualTime
Informs the smallest value found on data inside the sampling interval defined in the @sampleInterval parameter, except that the timestamp corresponds to the moment the smallest value found occurred
MinimumActualTime2
Informs the smallest value found on data inside the sampling interval defined in the @sampleInterval parameter, except that the timestamp corresponds to the moment the smallest value found occurred. It considers the Simple Bounding Values
NumberOfTransitions
Informs how many transitions occurred inside the sampling interval between values 0 (zero) and 1 (one)
PercentBad
Returns a percentage of time, relative to the time of the sampling interval, in which data had bad quality
PercentGood
Returns a percentage of time, relative to the time of the sampling interval, in which data had good quality
PercentInStateNonZero
Returns a percentage of time, relative to the time of the sampling interval, in which the value remained different from 0 (zero)
PercentInStateZero
Returns a percentage of time, relative to the time of the sampling interval, in which the value remained in 0 (zero)
Range
Returns the difference between the smallest and the greatest value found inside the sampling interval informed in the @sampleInterval parameter. Ignores bad quality values
Range2
Returns the difference between the smallest and the greatest value found inside the sampling interval informed in the @sampleInterval parameter. Ignores bad quality values and considers the Simple Bounding Values
StandardDeviationPopulation
Returns the population standard deviation (n) in the requested interval. It includes the Simple Bounding Values
StandardDeviationSample
Returns the sampling standard deviation (n - 1) in the requested interval
Start
Equivalent to the Interpolative function, but uses the original timestamp from the first value of the sampling interval
StartBounds
Equivalent to the Interpolative function, but uses the original timestamp from the first value of the sampling interval. It considers the Simple Bounding Values
TimeAverage
Calculates the weighted average by time using the Interpolated Bounding Values method inside the sampling interval defined in the @sampleInterval parameter
TimeAverage2
Calculates the weighted average by time using the Simple Bounding Values method inside the sampling interval defined in the @sampleInterval parameter
Total
Returns the sum of data from the sampling interval defined in the @sampleInterval parameter
Total2
Returns the sum of data with good quality from the sampling interval defined in the @sampleInterval parameter
Trend
Interpolates queried data for a better visualization on charts
VariancePopulation
Returns the variance for the StandardDeviationPopulation function
VarianceSample
Returns the variance for the StandardDeviationSample function
WorstQuality
Returns the worst quality found in the interval specified in the @sampleInterval parameter
WorstQuality2
Returns the worst quality found in the interval specified in the @sampleInterval parameter. It considers the Simple Bounding Values
Resulting Fields
•Name: Name of the variable or variables queried
•Timestamp: Timestamp of data
•Quality: Quality of data
•Value: Value of data
Usage Example
To return data from variable RandomTags_Random1 in the period between 10:23 and 11:23 on 12/07/2020, with a timezone of -3 (minus three) hours and interpolated at every 5 (five) minutes, use the next declaration.
SELECT Name, Timestamp, Quality, Value FROM EpmQueryAggregateFunction(-3, '2020-12-07 10:23:00', '2020-12-07 11:23:00', 300000, 'Interpolative', 'RandomTags1')
