EpmExpressionVariablesView
Returns a table with a list of all existing expression variables on an EPM Server.
Syntax
SELECT * FROM EpmExpressionVariablesView()
Resulting Fields
Name: Name of the expression variable
Description: Description of the variable
Usage Example
To return data from all expression variables whose names contain the expression "kpi" in the Name field, use the next declaration.
SELECT * FROM EpmExpressionVariablesView() WHERE Name LIKE '%kpi%'
