Usage
Usage
EPM ODBC Driver allows executing queries to an EPM Server in applications with the ODBC data source functionality, such as Excel and Power BI, or even on a Python environment. ODBC's language is similar to SQL, but in this case only uses the SELECT statement with one of the query functions described on this Manual.
There are several query functions that can be used to retrieve tables with relevant data. These functions make it easy to access from an EPM Server. The next topics describe each one of these functions.
