EpmQueryRawData Stored Procedure
Executes a query on one or more variables, searching raw data stored in the informed period.
EpmQueryByDate(
  @timeZoneOffset float,
  @startTime      datetime,
  @endTime        datetime,
  @valuesPerNode  int,
  @returnBound    bit,
  @nodelist       nvarchar(max))
Where:
•timeZoneOffset: Timezone to consider. This value is a floating-point number ranging from -12 to 14
•startTime: Query's starting date. The date format depends on the database configuration
•endTime: Query's ending date
•valuesPerNode: Maximum number of records returned by this query. The value 0 (zero) in this parameter indicates that all query records must be returned
•returnBound: Indicates whether this query must return the value stored immediately before and after the informed interval
•nodeList: List with names of Data Objects to query. Users can also inform references and full paths on the Contextual Model, if they were contextualized
Usage example:
EXECUTE EpmQueryRawData 1, -2,
  '01/15/2013 12:00:00', '01/31/2013 12:00:00',
  0, 0, 'OpcTag04,OpcTag05'
In this case, the query returns all values from Basic Variables OpcTag04 and OpcTag05 from the second half of January.
NOTE
Notice that the list with the names of variables to query uses a comma as a separator, without additional spaces.
