Getting References to Objects
One of the most important features to consider when working with scripts in Elipse E3 is the separation between processes executed in a server and those executed in a client's interface (Elipse E3 Viewer). To work with scripts, users can manipulate:
•Server objects via server
•Server objects via Elipse E3 Viewer
•Viewer objects via the same Elipse E3 Viewer
However, users cannot directly manipulate:
•Viewer objects via server, because this is only possible by creating events in a Viewer, which are connected to variables in a server
•Viewer objects via another Viewer, because this is only possible by creating events connected to variables in a server
Such limitations come from the fact that, by definition, there is an independence between what an Elipse E3 Viewer's station is performing or viewing and the server, and vice versa. So, all activities, both in a server and in Elipse E3 Viewer, need to be coordinated either in an asynchronous way or through events, to operate harmoniously.
Thus, due to this independence, when creating a script, first users must obtain a correct reference to the objects they want to manipulate, that is, an object must be first found on several Elipse E3 modules.
Remember that when users edit a script, they can use AppBrowser, which allows the path of a method or property to be completely copied to the script, thus helping the creation of scripts.
Therefore, to access external objects being manipulated in a script, some basic guidelines are used. For example, if users want to manipulate the value of an I/O Tag, the path is Server - Driver - Folder (if available) - Tag. But if their goal is to manipulate a button on a Screen, the path is Viewer - Frame (if available) - Screen - Button.
The source locations for scripts, according to the methodology for accessing objects, are the following:
•Server
•Screens and Frames (Elipse E3 Viewer)
•ElipseX (libraries): they can be XFolders, XObjects, which execute on a server, or XControls, which execute on an Elipse E3 Viewer
