Documentation
Documentation
•Added a new E3DBEngine section on E3 Tweak User's Manual with an option to disable thread pool, which was previously documented on E3Run section. This bug occurred since v4.6.118.
•Fixed several links on Elipse E3 documentation.
•Fixed the description of the Shift parameter on KeyDown and KeyUp events of Screens and Screen Objects on Elipse E3 Reference and Scripts Manual, which wrongly indicated a combination of a key with a mouse click. This bug occurred since v1.20.440.
•Updated the documentation of methods on Elipse E3 Reference and Scripts Manual to clearly state the behavior of a method in cases where some of its parameters is omitted. This bug occurred since v2.5.194.
•Changed the note on the IIf method on Elipse E3 Reference and Scripts Manual to fix the example expression of its Condition parameter. This bug occurred since v3.5.271.
•Fixed the description of OPC UA Block Tag's WriteEx method on Elipse E3 Reference and Scripts Manual. This bug occurred since v4.8.161.
•Added descriptions for AddField and RemoveAll methods of the Collection of Storage Fields on Elipse E3 Reference and Scripts Manual. This bug occurred since v4.0.13.
•Fixed the description of the GetTickSpacing method of the Axis on E3Chart's Collection of Axes on Elipse E3 Reference and Scripts Manual. This bug occurred since v1.20.275.
•Fixed the call to a Pen's Connect method in the description of Pen's ScaleX and ScaleY properties on Elipse E3 Reference and Scripts Manual. This bug occurred since v1.20.281.
•Fixed the description of the MaxGapTime property of an E3Chart's Pen on Elipse E3 Reference and Scripts Manual. This bug occurred since v3.5.162.
•Fixed the default value of the BkColor property of an E3Chart's Pen on Elipse E3 Reference and Scripts Manual. This bug occurred since v1.19.87.
•Fixed the links to the Item method of E3Chart's Collection of Axes on Elipse E3 Reference and Scripts Manual. This bug occurred since v4.5.119.
•Fixed the description of GetTickSpacing and SetTickSpacing methods on Elipse E3 Reference and Scripts Manual to state that these methods return or configure divisions of an E3Chart's scale, not subdivisions.
•Updated the description of the ReferenceLineStyle property on Elipse E3 Reference and Scripts Manual to state the number values of each one of the options for this property. This bug occurred since v4.8.53.
•Fixed the spelling of the DblClick event on Elipse E3 Reference and Scripts Manual.
•Fixed the style of the description of the RemoveSubCondition method of a Discrete Alarm's Collection of Subconditions on Elipse E3 Reference and Scripts Manual. This bug occurred since v4.0.192.
•Updated the description of the GetAlarm method, common to all Alarm Sources, to state the Discrete Alarm Source on Elipse E3 Reference and Scripts Manual. This bug occurred since v4.0.192.
•Updated the Elipse E3 Reference and Scripts Manual to contain information about the Source object returned by several properties of Screen objects and MS Forms.
•Updated topic Layer on Elipse E3 Tutorial Advanced to fix an information that Screen's Layer property, when configured to 0 (zero), hides all Screen objects. This bug occurred since v4.7.120.
•Updated topic Screens and Screen Objects - Screen Objects - General Configurations - Layers on Elipse E3 User's Manual with information about the new configuration screen for Screen layers. This bug occurred since v4.5.61.
•Fixed the content of topic Domains - Configuration - Security Tab on Elipse E3 User's Manual. This bug occurred since v4.8.205.
