Other Implementations |
•Created the option HeapLog.{PROCESS} in Windows Registry to generated detailed logs about memory usage of Elipse E3 processes.
•Added the option OANOCACHE in Elipse E3 log configuration in Windows Registry, which allows disabling the BSTR cache of OLE Automation. NOTE: It should be enabled only to improve BSTR memory leak diagnosis, because it degrades memory allocation performance for Strings.
