Remote Domains
Remote Domains
•Improved the limit time and implemented a heartbeat during the REC connection of Remote Domains and Hot-Standby, as well as improved the limit time of connection of Elipse E3 Studio with E3 Server. This corrects a problem with the Client Domain not reconnecting to the Server after several disconnections, due to network problems.
•Corrected a problem in reconnecting Remote Domains when the Client Remote Domain delayed several minutes to update or start the Domain. This bug occurred since v3.0.201.
•Corrected a problem in the threads for reconnecting and sending data from Remote Domain clients, to ignore Windows message floods, which makes the Client Remote Domain to fail on reconnection. This bug occurred since v3.0.201.
•E3 Server no longer hangs when there are too many accesses to a Remote Domain from which alarms are viewed. This bug occurred since v3.0.201.
•Improved the performance of the GetObject method when called by a Elipse E3 Viewer or by Remote Domains.
•Revised the management of alarm subscription connections in E3 Server, fixing failures (GPFs) and increasing asynchronous operations. This bug occurred since v3.1.68.
