Properties
Properties
Every object contains Properties, which are used to save information about its features. For example, a Rectangle-type object contains a Name property, which stores its name, and the Width and Height properties, which store its width and height, respectively, among other properties.
This chapter lists all common properties of Elipse E3 objects. Each topic contains the name of the property, its description and, when applicable, an example of its usage. Properties are identified by an icon indicating the data type supported by their content. The available data types are described on the next table.
Available data types
Data Type
Description
Boolean Boolean
Represents True or False values
Collection Collection
Represents a collection of objects
Collection Item Collection Item
Represents an item on a collection of objects
Color Color
Represents a color in RGB format
Date and Time Date and Time
Represents a date in the Gregorian calendar (beginning in 1899)
Enumeration Enumeration
Represents a determined set of values
Font Font
Represents a font applied to a text
GUID GUID
Represents a GUID (Globally Unique Identifier) value
Indexed Property Indexed Property
Represents a property whose values can be accessed by an index
Link Link
Represents a link between objects
Number Number
Represents an integer or Double value, positive or negative, to be defined by the property
Picture Picture
Represents an image in BMP, EMF, GIF, ICO, JPEG, PNG, TIFF, or WMF format
Text Text
Represents a text
Variant Variant
Represents a variable value, which can assume several formats
Some properties can propagate their values to the same property in their child objects. In this case, they are called propagating properties. Users can, however, force a child object's property to behave in a different way.
NOTE
Elipse E3 uses the Himetric system to define coordinates and widths. In this system, each logical unit is equivalent to a thousandth centimeter, that is, 1,000 units are equivalent to one centimeter. Thus, this is the standard adopted when describing Elipse E3 properties, when applicable.
The available properties on this section are the following:
•Application
•Count
•DocString
•ExposeToOpc
•IsObjectActive
•Links
•Name
•ObjectEvents
•Parent
•PathContainer
•PathName
•PathVolume
