Methods
Methods
This section contains information about the common methods of Elipse E3 objects. Each topic displays the name of a method with its respective parameters, in its correct syntax, and also a usage example. The available methods on this section are the following:
•Activate
•AddObject
•Context
•Deactivate
•DeleteObject
•GetChildObject
•GetObject
•Item
•RunEvent
•RunProcedure
•Save
