Define an Interval Between Process Statistics |
This section allows configuring time options for recording process statistics. Available options in this section are described on the next table.
Options for interval between process statistics
Module |
Description |
E3Admin |
Configures an interval between E3 Admin's process statistics. Default value of this option is 60 |
E3DBEngine |
Configures an interval between E3DBEngine's process statistics. Default value of this option is 60 |
E3IoServer |
Configures an interval between E3IoServer's process statistics. Default value of this option is 300 |
E3OpcClient |
Configures an interval between E3OpcClient's process statistics. Default value of this option is 60 |
E3Run |
Configures an interval between E3Run's process statistics. Default value of this option is 60 |
E3Server |
Configures an interval between E3Server's process statistics. Default value of this option is 60 |
E3Studio |
Configures an interval between E3Studio's process statistics. Default value of this option is 60 |
E3UaClient |
Configures an interval between E3UaClient's process statistics. Default value of this option is 60 |
E3Viewer |
Configures an interval between E3Viewer's process statistics. Default value of this option is 60 |
NOTE |
For all modules, a value of 0 (zero) disables statistical recording. Using a value between one and nine forces Elipse E3 to use a value of 10. All values are in seconds. |
