Frequently Asked Questions |
possible reason
Another version of Elipse E3, Elipse Power, or Elipse Water is installed and opened while trying to install Elipse E3.
SOLUTION
Close the open modules of Elipse E3, Elipse Power, or Elipse Water and then resume Elipse E3 installation.
Possible Reason
The installation of another Elipse Software product was started but it is still pending while trying to install Elipse E3.
Solution
Finish the pending installation and then resume Elipse E3 installation.
possible reason
An Elipse SCADA version is installed and opened while trying to install Elipse E3.
SOLUTION
Close Elipse SCADA and then resume Elipse E3 installation.
possible reason
There are two possible reasons:
a)Protection device or detection drivers are not correctly installed.
b)USB port setup is not correct or this port is damaged.
SOLUTION
For each reason, try the following:
a)Execute HaspDinst.exe application with -I option. This can be performed via Start - Run menu. The command prompt would be, for example:
C:\Program Files\Elipse Software\Elipse E3\HASP\haspdinst.exe -I
b)Test USB port with another known device, such as a printer. Users can also check on computer settings whether this USB port is correctly configured.
For more information about Elipse E3's Demo mode limitations, please check topic Limitations of Demonstration Mode on Elipse E3 User's Manual.
possible reason
Path to picture files is incorrect.
SOLUTION
Users must create the same directory structure, that is, the same path from the original computer.
