Animation
Animation
1.Select the Gallon object and click Linear Slider to insert a Linear Slider. A shadow of this object appears. Move it as needed.
Linear Slider
Linear Slider
2.Right-click the Linear Slider and open its Properties window. Create a Link from the Value property to the Animate Tag.
Link with the Animate Tag
3.Change Linear Slider's Enabled and EnabledSlider properties to False.
