<< Click to Display Table of Contents >> Data Server |
Some objects that can be inserted in a Data Server are described on the next table.
Objects that can be inserted in a Data Server
Object |
Description |
Counter Tag |
Object that performs a time counting, in seconds, until it reaches a pre-determined value, or that executes a certain time counting indefinitely |
Demo Tag |
Object that generates values according to a wave form. It is used to simulate values. It allows generating pre-defined curves or random values |
Internal Tag |
Generic-purpose object, used to store any type of value, including numbers, texts, and other objects |
Timer Tag |
Object for time counting and activity scheduling. Establishes a schedule, with repetitions, to perform actions |
Data Folder |
Defines groups and sub-directories to organize information. New folders can be inserted inside others, if needed |
