<< Click to Display Table of Contents >> E3Chart |
•Because of performance issues, dotted Pens with width 1 (one) are now drawn the same way as Pens with width zero. This bug occurred since v3.2.68.
•Fixed a problem causing a real time part of a Real Time & Historic Pen not displaying if the historic part query was incorrectly set. This bug occurred since v3.1.189.
•Fixed a problem when using complex field names in Storage fields with E3Chart Pens. This bug occurred since v2.5.15.
•Fixed a GPF in Historic Pen expressions. This bug occurred since v3.2.89.
•Fixed a problem in E3Chart causing the historic part of a Real-Time Pen to be plotted in certain configuration combinations. This bug occurred since v3.1.189.
•Starting an E3Chart query is now asynchronous, avoiding Elipse E3 Viewer locks in case a Database connection is slow. This bug occurred since v1.19.87.
