<< Click to Display Table of Contents >> Playback |
•Fixed a bug that caused E3Playback queries to fail if the Alarms table was using EventTimeDbl field, and if the database was an Oracle server. This bug occurred since v3.1.115.
•Fixed a bug in playback data loading, which failed with an 80020005 error in case any field definition table had a NULL value, which usually occurred only if users updated tables manually.
•E3Playback's events list now supports double-click on an event to move the playback's clock to the time of the event. This behavior also works on Play mode, or if the event had already been selected on the list. This bug occurred since v3.1.189.
