Value
Value
Variant This property specifies the value the property assumes when the source is within the specified Row's interval. The next script contains an example of using this property.
Sub CommandButton1_Click()
  Dim Color
  ' Picks a color
  Application.ShowPickColor Color, 0, 100, 100
  Screen.Item("Rectangle1").Links.Item("ForegroundColor")._
    Item(1).Value = Color
