<< Click to Display Table of Contents >> Alignment |
This property specifies an object's position, relative to its legend. Possible values for this property are 0 - fmAlignmentLeft: Aligns the legend to an object's left side or 1 - fmAligmentRight: aligns the legend to an object's right side (default). This property cannot be changed while this object is active.
