<< Click to Display Table of Contents >> CanPaste |
This property specifies whether the Clipboard contains data supported by this object. If this property is set to True, an object can receive information pasted from the Clipboard. If data from Clipboard is in a format that an object does not support, the value of this property is set to False. For example, when trying to paste a bitmap to an object that only supports text, this property is set to False. This is a read-only property.
