HeaderBorderStyle
HeaderBorderStyle
Enum Defines a style for the borders of Legend's header columns. The available options for this property are described on the next table.
Available options for the HeaderBorderStyle property
Option
Description
0 - lbsFlat
Applies a flat border to the header column
1 - lbsRaised
Applies a border raised on its upper left side and a shadow on the lower right side of the header column
2 - lbsSunken
Applies a border with a shadow on its upper left side and raised on the lower right side of the header column (default)
3 - lbsEtched
Applies a border that looks etched around the edges of the header column
4 - lbsBump
Applies a border with a ledge on its lower right side and that looks flat on the upper left side of the header column
