SetValueData
SetValueData
SetValueData(ValueName, TemplateName, Data)
Changes the value referring to a Template defined for a certain Set of Values. This method contains the ValueName parameter, which is the name of a Set of Values, TemplateName, which determines the name of a Template, and Data, which is a value to set to that Set of Values. This method performs a check for limits and returns True if that operation is successful or False otherwise.
NOTE
For more information about this method, please check articles Working with Formulas in Elipse E3, Creating a Value Set at Run Time, and Changing a Value Set at Run Time on Elipse Knowledgebase.
