<< Click to Display Table of Contents >> FetchData |
FetchData(eof)
Triggered every time a new record is processed. This event is used to execute a script that changes the values of fields added to a Section Report in a script linked to the DataInitialize event. The default value of the eof parameter is True and indicates that after the script, the processing of the current record of the Section Report is finished.
