<< Click to Display Table of Contents >> GetE3QueryFields |
GetE3QueryFields()
This method returns a Fields Collection or columns of a Query. Every item on that Collection contains properties that can be modified, as described on topic Query Field. The next script contains an example of using this method.
Sub Button1_Click()
' Traverses the Fields Collection,
' displaying the fields on a message box,
' and also setting them as visible
' on Query's configuration
Set Browser = Screen.Item("E3Browser")
Set Query = Browser.Item("Query")
Set Fields = Query.GetE3QueryFields()
For Each field In Fields
MsgBox CStr(field.TableName) & "-" & CStr(field.ColumnName)
field.Visible = True
Next
' Performs E3Browser's Query again, which has been
' just modified, so that all fields appear.
Browser.RetrieveE3QueryFields()
Browser.Requery()
NOTE |
To use this method, the Query must be previously created at design time. |
