CursorLocation
CursorLocation
Enum Defines where the Query is generated and handled, from a DBMS (Database Management System) point of view. Possible values for this property are 0 - clServer: Query is generated on the DBMS (server) or 1 - clClient: Query is generated on the Server (client, default). For more information, please also check the CursorType property.
NOTE
This property has no effect for Databases with the SourceType property equal to 0 - stAccess, because in this case the Server always generates and handles the Query. However, for SourceType equal to 1 - stOracle or 2 - stSqlServer, it is advisable to use the option 1 - clClient. For more information, please check the documentation of the CursorLocation property and the CursorLocationEnum enumeration of the ADO (ActiveX Data Object) object.
