Action
Action
Enum This property defines an E2Button object's behavior when clicked. Possible values for this property are 0 - MOMENTARY: Standard button behavior, appearing lowered only when pressing this button (default), 1 - TOGGLE: It has two states, turned on and turned off, or 2 - JOG: Switches between two values, one when this button is pressed and another one when this button is released.
