<< Click to Display Table of Contents >> MinimumValue |
This property determines the minimum value reached by a Scale. The default value of this property is 0 (zero). The next script contains an example of using this property.
Sub CommandButton1_Click()
' When clicking this button, opens a MessageBox
' indicating the minimum value for this property
MsgBox _
CSTr(Application.GetObject("Data.Scale1").MinimumValue)
