<< Click to Display Table of Contents >> AverageY |
Informs the average of a Pen in an interval, if the EnableCalc property is enabled. If an E3Chart is in Interval Search mode, displays the average of this interval. Otherwise, displays the interval between the beginning and the end on the Horizontal Axis. Values with bad quality are not considered if the ShowBadPoints property is disabled. This is a read-only property.
