NetLibrary
NetLibrary
Enum Configures the type of network library of a Database. Possible values for this property are described on the next table.
Available options for the NetLibrary property
Option
Description
0 - Default
Default type library
1 - NamedPipes
Named Pipes-type library
2 - TcpIp
Winsock TCP/IP-type library
3 - SpxIpx
SPX/IPX-type library
4 - BanyanVines
Banyan Vines-type library
5 - MultiProtocol
Multi-protocolo (RPC)-type library
NOTE
This property is only available on SQL Server-type databases.
