<< Click to Display Table of Contents >> Alarm |
Indicates that there are active Alarms inside an Area. If this option is set to True, there is at least one active Alarm inside an Area, and the ActiveAlarms property performs a reading from a server, then indicating the number of active Alarms. Otherwise, the ActiveNACKAlarms property performs a reading on non-acknowledged Alarms. This is a read-only property.
