<< Click to Display Table of Contents >> BlinkOn |
When this property is set to True, the connected property alternates periodically between values of OnValue and BlinkOnValue properties, in case the source returns True. The next script contains an example of using this property.
Sub BlinkOn_Change()
On Error Resume Next
Dim Bind
Set Bind = Screen.Item("Rectangle1")._
Links.Item("ForegroundColor")
If Bind Is Nothing Then
MsgBox "Rectangle1 has no link."
Else
MsgBox "Rectangle1 is linked to " & Bind.Source & "'"
MsgBox "Changing BlinkOn from " &_
Bind.BlinkOn & " to "_ & Value
Bind.BlinkOn = Value
End If
