MousePointer
MousePointer
Enum This property specifies a type of mouse pointer displayed when users move it over an object. Possible values for this property are described on the next table.
Available options for the MousePointer property
Option
Description
0 - fmMousePointerDefault
Default mouse pointer (this image is determined by the object)
1 - fmMousePointerArrow
Arrow-shaped mouse pointer
2 - fmMousePointerCross
Cross-shaped mouse pointer
3 - fmMousePointerIBeam
I-beam-shaped mouse pointer
6 - fmMousePointerSizeNESW
Double arrow pointing to North-East and South-West
7 - fmMousePointerSizeNS
Double arrow pointing to North and South
8 - fmMousePointerNWSE
Double arrow pointing to North-West and South-East
9 - fmMousePointerWE
Double arrow pointing to West and East
10 - fmMousePointerUpArrow
Arrow pointing up
11 - fmMousePointerHourglass
Hourglass
12 - fmMousePointerNoDrop
A Not symbol (a circle with a diagonal line) on the upper side of the dragged object (indicates and invalid drop destination)
13 - fmMousePointerAppStarting
Arrow with an hourglass
14 - fmMousePointerHelp
Arrow with a question mark
15 - fmMousePointerSizeAll
Resizes the whole mouse pointer (arrows pointing to North, South, East, and West)
99 - fmMousePointerCustom
Uses an icon specified by the MouseIcon property
Use this property to indicate a change in functionality as the mouse pointer hovers Screen objects. For example, an hourglass-shaped pointer (the 11 - fmMousePointerHourglass option) is useful to indicate that users must wait for a process or operation to finish. Some icons may vary, depending on system configuration, such as icons linked to desktop themes. The default value of this property is 0 - fmMousePointerDefault.
