Frequently Asked Questions
During installation, a message "There are E3 modules running on this machine. Please stop them and restart installation" is displayed
possible reason
Another version of Elipse E3, Elipse Power, or Elipse Water is installed and opened while trying to install Elipse E3.
SOLUTION
Close the open modules of Elipse E3, Elipse Power, or Elipse Water and then resume Elipse E3 installation.
During installation, a message "There is an Elipse E3, Elipse Power, or Elipse Water installer already running on this machine. Please close and finish the previous installation" is displayed
Possible Reason
The installation of another Elipse Software product was started but it is still pending while trying to install Elipse E3.
Solution
Finish the pending installation and then resume Elipse E3 installation.
During installation, a message "Files in use. Files that need to be updated are in use" is displayed
possible reason
An Elipse SCADA version is installed and opened while trying to install Elipse E3.
SOLUTION
Close Elipse SCADA and then resume Elipse E3 installation.
After installation, a message "Elipse E3 Studio license not found in this server. Do you want to run in demo mode?" is displayed when I try to execute Elipse E3 Studio
possible reason
There are two possible reasons:
a)Protection device or detection drivers are not correctly installed.
b)USB port setup is not correct or this port is damaged.
SOLUTION
For each reason, try the following:
a)Execute HaspDinst.exe application with -I option. This can be performed via Start - Run menu. The command prompt would be, for example:
C:\Program Files\Elipse Software\Elipse E3\HASP\haspdinst.exe -I
b)Test USB port with another known device, such as a printer. Users can also check on computer settings whether this USB port is correctly configured.
For more information about Elipse E3's Demo mode limitations, please check topic Limitations of Demonstration Mode on Elipse E3 User's Manual.
I moved the application to another computer and now it does not display images anymore
possible reason
Path to picture files is incorrect.
SOLUTION
Users must create the same directory structure, that is, the same path from the original computer.
