ScreenAlignment
ScreenAlignment
Enum Controls the alignment, given by Elipse E3 Viewer, of all Screens that do not specify a value different from default. Possible values for this property are the following:
The next figure shows an Elipse E3 Viewer's contextual menu at run time, with the respective configuration options of this property.
Options for Elipse E3 Viewer's ScreenAlignment property at run time
