OnHide
OnHide
OnHide()
This event occurs when a Screen is about to be closed. Use this event to perform any operations before closing that Screen object. This event may occur on several situations:
•When a Screen is replaced by another one, by using the OpenScreen or ShowScreen methods
•When a user closes a window where that Screen is
•When the Close method is used from a Screen object
•When an Elipse E3 Viewer is closed or quit
The next script contains an example of using this event.
Sub InitialScreen_OnHide()
  Application.Exit()
