Exercises |
In this exercise, let's configure an option to copy the configurations of a pump and send them to all other pumps by using mouse's right-click.
1.Create an Internal Tag in Viewer named "CopyPump".
2.In XControl XC_Pump, select the group with a pump image and insert the next script on the MouseDown event.
If Button = 2 Then 'Right-click
If TypeName(Application.Item("CopyPump").Value) = "Empty" Then
Menu = "Copy"
Else
Menu = "Copy|Paste"
End If
optionMenu = Application.SelectMenu(Menu)
If optionMenu = 1 Then 'Copy
'Store information on Viewer's Tag
Dim arr(2)
arr(1) = XC_Pump.Source.Status
arr(2) = XC_Pump.Source.Speed
Application.Item("CopyPump").Value = arr
ElseIf optionMenu = 2 Then 'Paste
'Send information from Viewer's Tag to DataPump
arr = Application.Item("CopyPump").Value
XC_Pump.Source.Status = arr(1)
XC_Pump.Source.Speed = arr(2)
End If
End If
3.Save all changes and register the library.
4.Execute the application and test this new functionality.
