Other Implementations |
•Improved the security of REC channel's cryptography.
•Elipse E3 processes now generate minidump files on the logs folder whenever an unhandled error or exception is found.
•Updated the detection of the Warsaw security module by Diebold Nixdorf.
•Now Elipse E3 generates a minidump file with code E3000006 (Stalled) when there is a need to terminate a process in a forced way.
•Added logs for all DCOM's marshalling or unmarshalling failures.
•Now Elipse E3 processes are always closed in case of major failures, even if they are in DCOM calls.
