<< Click to Display Table of Contents >> Charts and E3Chart |
An E3Chart is an ActiveX component specially created to work with Elipse E3. With it, users can display charts with Tags varying in real time and also display historical data stored in a database.
Every data sequence is represented in an E3Chart using Pens. Each Pen contains data linked to it, which can be either Tags or Query fields. Users can create several Axes with different Scales to link to Pen's data.
E3Chart
To insert this object on a Screen, right-click it and select the Insert - E3Chart option.
