Area
Area
An Area object allows grouping a set of Alarm Sources, as well as other Alarm Areas. This facilitates the management, operation, and monitoring of a set of related Alarm Sources, allowing, for example:
Filtering a set of visible Alarms in a Summary
Enabling or disabling a set of Alarm Sources
Acknowledging a set of Alarm Sources
Checking the total number of active or unacknowledged Alarms of a set of Alarms Sources
If needed, new Areas can be inserted inside other Areas.
