<< Click to Display Table of Contents >> Reports |
A Report is an ActiveX component called ActiveReport, which allows viewing and printing instantaneous values from system variables and data stored on databases, such as Alarms, Historic objects, Queries, and Formulas. To use a Report, right-click Organizer's View - Reports item, in Domain mode, select the Insert Report in option, and then select a project's name.
A Report also uses a Query object. This object allows users to specify a database source for data viewed on a Report.
A Report contains several Sections. Each Section of a Report contains a group of controls that are processed and printed at the same time, as a unit.
