XC_Tank
XC_Tank
1.Insert a new XControl in the library and name it as "XC_Tank".
2.Configure it according to the next figure. Two Texts ("Name" and "00") and one Rectangle are used.
XC_Tank XControl
XC_Tank XControl
3.Create the Source Property to access the properties of the XFolder XF_AnalogMeasurement.
Source Property
Source Property
4.In the Text object used to display the level's value, change the format to Percent and one decimal place.
Text format
Text format
5.In the Text's Value property, create an Analog Link to the Value Property of the object XF_AnalogMeasurement, according to the next figure.
Analog Link in the Value property
6.In the Rectangle's VerticalPercentFill property, create a Simple Link to the Value Property of the object XF_AnalogMeasurement.
Simple Link in the VerticalPercentFill property
7.In the Name Text, change its Layer property to 2 (two).
8.Still in the Name Text, create a Simple Link to the Name Property of the object XF_Tank. As the Source Property accesses an XF_AnalogMeasurement object, users must add a "Parent" expression, which allows accessing the parent object of XF_AnalogMeasurement.
Simple Link in the Value property
NOTE
The Link in the previous procedure appears in red because a library cannot access the hierarchy of objects used in an application.
9.Save these changes and register the library.
