<< Click to Display Table of Contents >> Screen Objects |
•Fixed the zoom when performing a Screen fit in one dimension, specific to the alignment mode paTopLeft. This bug occurred since v1.18.155.
•Implemented a fix to Screen replacement after adding an object. This bug occurred since v5.0.424.
•Implemented a correction involving shortcut keys CTRL + Mouse wheel and SHIFT + Mouse wheel so that they are restricted to this combination, and the mouse wheel only to vertical displacement. This bug occurred since v5.0.395.
•Fixed repositioning windowed ActiveX controls on a Screen aligned to center when moved or resized. This bug occurred since v5.0.351.
•Fixed repositioning of Screen's visible area when changing zoom levels after finishing the Application Wizard. This bug occurred since v5.0.414.
•Fixed the drawing of the selection rectangle, if started from a transition of the Move mode. This bug occurred since v4.8.87.
•The zoom mode is no longer lost when an object is added or resized on a Screen. This bug occurred since v5.0.415.
•The status bar now displays information correctly when a Screen is created and updated when zoom changes, even if focus is not on any object of the Design tab. This bug occurred since v2.0.45.
•Improved conversion of images of type EMF (Enhanced Metafile) and WMF (Windows Metafile) to symbol. This bug occurred since v1.18.147.
•Now Screen objects pasted on a group appear correctly in their original position. This bug occurred since v5.0.337.
