Studio
Studio
Added shortcut keys in Elipse E3 Studio for the Saves and Runs the Domain (F9), Run or Stop Domain (SHIFT + F9), and Run or Stop Elipse E3 Viewer (CTRL + F9) options.
Added options to access Elipse Knowledgebase, Elipse Software channel on YouTube, and Elipse Software Driver's download page on Elipse E3 Studio's Help menu.
When creating or saving an object, a Folder, or a Resource, Elipse E3 version used to save them is now registered. When executing an application, saved versions of every object are registered on logs.
Elipse E3 Studio now displays a warning to users in case they try to add a library copied from an existing one. In addition, the Domain Verifier is now opened when finding errors in a Domain when executing an application.
Elipse E3 now uses the Common Controls 6.0 library.
Standardized the size of text and date and time edition boxes to fit a Spin Button.
Removed the single tab on WatchWindow window.
Implemented a new shortcut for the Show in Editor command, a double-click or press the ENTER key on an item in Organizer or Explorer.
Created shortcut keys for Elipse E3 Studio windows (Organizer, Gallery, Properties List, etc.).
Changed the terminology for the Domain or Object Verification.
The configuration window of Digital, Analog, Table, and Multiple Links now allows receiving keyboard focus using shortcut keys CTRL + ENTER and ALT + Down arrow when focus is on Link's row and column.
Created the DeleteFile method to delete objects from project files by script in Studio.
Implemented new styles or themes for Elipse E3 Studio and changed the default theme.
