<< Click to Display Table of Contents >> Domain Library File Information |
This section contains information about the properties of a Domain Library File Information (LibFileNode) object. This object does not contain events nor methods associated to it.
NOTE |
Using brackets when referencing this object in scripts, such as "[?Server].Domain.Files.Lib.Library_Name", is mandatory. |
