Trace
Trace
Trace(MessageText, [LogTimeStamp], [BreakLine])
This method allows registering messages in Elipse E3's log. This method can be used, for example, to register debugging messages for scripts executed in Elipse E3 Viewer.
Parameters of the Trace method
Parameter
Description
MessageText
A user-defined message
LogTimeStamp
A Boolean indicating whether each record must contain a timestamp. This parameter is optional and ignored in Elipse E3 Viewer
BreakLine
A Boolean indicating whether a line break must exist at the end of each message. This parameter is optional and ignored in Elipse E3 Viewer
